Anonymous
Jun 29, 2016Not applicable
An exchange of 20 degrees is just about all you can expect from any A/C system, including ones inside of a home. With temperatures so high and that long of a trailer, a second AC might end up being your best bet if you have that option. I wouldn't bother swapping out the 13.5k for a 15k. A single 13.5k may work if you can get in some shade, turn it on early, and let it run all day. Even then you'll still see some creep in the temperature as the day gets hotter, but it shouldn't become unbearable. Vents and skylights are pretty much uninsulated holes in your roof. Vent pillows can help even if you are in the shade.
