docnascar
Nov 02, 2019Explorer
Blow out water lines question
First time trying the blow out method. The one thing that I typically dont see is what do folks do with the freshwater pump?
The one thing I read was to fully drain the freshwater tank. Then turn the pump on and let it run until no water comes out and then continue for another 15 20 seconds to continue to clear out any remaining water in the pump. Is that sufficient?
I've used no pink stuff in any lines, just air. I did put the pink stuff in the traps and in the toilet bowl.
Also my GD 2400BH has a black tank water inlet for a spray bar to clean inside of the black tank. Is it necessary to blow the line for that considering there are no valves and it's not pressurized? I already did it but just curious if its needed.
