1. Purchase a
blowout plug.
2. thread it into the city water hookup spot on your RV.
3.Set your compressor to 40-50lbs output.
4. Open a faucet inside the trailer.
5. Connect hose from compressor to blowout plug.  You can get a device that will hold the hose on the plug or have a partner hold it on there.
6.  Open up all the faucets, one at a time, in the trailer.  Don't forget to flush the toilet - including the sprayer if you have one.  I usually open a new faucet before closing the previous one just to make sure I don't build up too much pressure in the lines.
7.  If you have a black tank rinse system, make sure you blow out that line also.
8.  Pour a bit of pink antifreeze into each drain and into the toilet.
9. On my trailer, there is a valve on the water pump line for winterizing that I can open to force air back through the pump to the fresh water tank.  I open that to clear any water out of the pump.  If you don't have one, then I would take a line off the pump and blow it out that way.
You are done! :)
Barney
