Bumpyroad
Sep 20, 2014Explorer
cdru wrote:
So, if I open the WH bypass valve, would any water above the valve simply run into the WH? A small amount in the WH shouldn't hurt anything. Everything else, including the cold and hot faucets etc, were blown out properly. Thanks
if you open the hot out it might go back into the WH but the rest of the line wouldn't drain.
I'd repeat the procedure and do it right. in Northern Minnesota I would say doing it right would be to also add antifreeze to the system.
bumpy
