Gdetrailer
Sep 21, 2014Explorer III
Bumpyroad wrote:Gdetrailer wrote:
Seems to me I read quite a few posts this spring and perhaps last spring also of folks who used the pink stuff WITHOUT blowing out the water first which resulted in BROKEN water lines.
The pink stuff ONLY works when it is used FULL STRENGTH.
ANY dilution by any amount of water WILL RENDER it USELESS.
The problem however with depending on the pink stuff is the manufactures CAN CHEAT and dilute it further than they should WITHOUT YOUR KNOWLEDGE.
I HAVE personally ran into this issue with the blue windshield washer fluid! Several winters ago, I FOUGHT with several jugs of windshield washer fluid (I bought them at the same place at the same time) which FROZE COMPLETELY SOLID IN THE LINES AND TANK. The temperatures, 20F-25F ABOVE ZERO! The blue stuff should be good WELL below that.. I basically bought blue colored water :M
:B
60 minutes should investigate this dilution of blue windshield washer fluid and pink RV antifreeze for this clandestine activity. I didn't happen to note a great influx of broken plumbing last winter being reported myself.
and "any dilution will render it useless". If I have some spare time to waste, I think I will do a study of various dilutions and see what happens. since the pink stuff may slush up, it will be hard to tell exactly how much "slushing up" is done per dilution however.
bumpy
Do you know what type of RV/Marine antifreeze you are buying?
Do you realize that there ARE different types of RV/marine antifreeze?
There ARE at least THREE distinct "types" of RV antifreezes.
Per HERE you have an Ethanol (alcohol) based, Propylene Glycol Based and a Propylene Glycol/Ethanol MIX based.
Unlike what the website I referenced above says you can buy both Propylene Glycol and the Propylene Glycol/Ethanol mix in most retail stores.. Walmart has them side by side on the shelves.
Good pink stuff (propylene glycol) $11.40 a gallon
HERE
Cheap pink stuff (Propylene Glycol/Ethanol (alcohol) mix) $3.47 gallon
HERE
Both of the above can provide "freeze protection" but that freeze protection listed on the bottle is ONLY GOOD if you do not dilute it any further OR the bottler does not dilute it..
Additionally the cheap pink stuff since it contains a considerable amount of Ethanol is going to be harsh to many rubber seals (toilet, faucet valves, tank valves, water pump and pressure switch, Water pressure accumulator tank with bladder if you have one, and even perhaps the water lines..
Most people are not going to pay the $12 price tag of the straight Propylene Glycol..
At $12 a gallon you are not going to want to run more than you have to through the system so most folks are going to shut off the spigots when it STARTS to turn pink which IS WELL BEFORE they get ALL the water out of the system..
By the way, if you are buying the expensive pink stuff then you can buy a tester made for propylene glycol instead of guessing on how pink it looks..
