D_and_A_plus_6's avatar
Apr 09, 2015
Blowing out water lines?
We camping over Easter for the First trip of the season. Went to Arrowhead County Park in Neola Iowa and had a great weekend. When we got ready to leave and not knowing when we were going to go camping again, I blow out my water lines and drained my hot water heater, so the water wouldn't get stale or old setting in the lines.
Was this over kill, or do several of you do the same thing. At the time, with baseball/softball season approaching, it may be at least Father's Day weekend before we'd be out again.
Thanks for any inputs or other ideas.
  • I will offer a different opinion. Do remember science class an the petri dish growing bacteria? Introduction of air (with bacteria) in a moist environment is not a good thing. I would sanitize the system before use if you drink the water.
    That said I always drain my water heater when I'm not going to use it for a while. Just make sure power is off or element is toast.
  • Just make sure your water heater is off(or you refill water heater) before you plug into electric again. Empty tank means instant element burnout.
  • I only blow mine out when there is freezing temperatures. There is no harm to leaving the lines pressurized. If you want to relieve some pressure just turn off the water pump (with city water not attached of course) then open each faucet for a second. If you're worried about contamination just let the water run for 10 seconds or so when you use the trailer after and extended period of sitting. IMO there's really no harm to letting it sit. The materials are basically the same stuff as in a house and people let that sit for years sometimes and it does fine.
