pappaone's avatar
pappaone
Draining water lines
Hello,
I'm getting ready to winterize my 2017 Winnebago Minnie Winnie 27Q MH. Reading the operators guide it states there should be Two (2) water system drain valves and the water heater bypass valve behind a panel located underneath the range/oven. Panel removed and bypass valve is visible but do not see the water drain valves. Is by chance the manual wrong or am I over looking the valves. Any Minnie Winnie owners out there that can guide me.
Thank You
