pappaone wrote:
SidecarFlip wrote:
You put the HWH in bypass and pull the plug on the bottom to drain it (after you relieve the pressure first with the T&P valve on the top.
SidecarFlip, how does this drain the hot and cold water lines I don't follow
ps..where in S E Michigan, I'm from a little town named Cassopolis
Drains the HWH and if you don't relieve the pressure (like I forgot to do this rime around), you get a bath..lol
One thing about the bath, it was loaded with what flaked off the anode rod, so I got a bath and had a bunch of white flakes all over my sweatshirt..
I live between Deerfield and Petersburg on the west edge of Monroe County just south of M50. Out where the buses don't run....
