jbird68
May 26, 2017Explorer III
Water Line routing.
I discovered that I had a water line leak in my Jayco Designger 12F5. I want to replace the line but I have an issue. The original lines are routed on top of the main floor but under the slide out. This makes it hard to gain access under the slide-out to repair the leak. Is there any reason why I can't re-route the lines under the flooring?
