Johno02
Sep 03, 2013Explorer
Check the lines between the water tank and the water pump. There may be a T and fitting for winterizing. Mine has a valve in the line before the pump, and a fitting to attach a hose to the AF bottle. Just attach the bottle, rotate the valve, then pump AF through the entire system with the water pump.
44,071 PostsLatest Activity: Aug 30, 2026
