73guna wrote:
coolbreeze01 wrote:
Raise enough with the jack and chains can be latched/unlatched with your fingers. No pressure, no danger.
LOL.
Ive nearly had my back tires ready to come off the ground and it was still hard to turn.
Because of the danger of the twist latches Ill probably end up going back to Equalizer.
Ive been smacked a few times unlatching even with a breaker bar.
If you use a ratchet instead of a breaker bar, it will "release" by rotating through the ratchet action. Doing it this way, it is impossible for it to hurt you. The sudden noise of it releasing may scare the daylights out of your dog though !
