PolarisRich's avatar
PolarisRich
Help!!! 2016 F150 with Blue Ox SwayPro measurements!
I recently purchased a 2018 Coachmen Apex 245BHS. I picked it up a few days ago and the drive home from the dealer was a 2 1/2 hour white knuckle nightmare to say the least! I know some of the problem was the weather that day, it was blowing steady 30 with gusts 45-50mph crosswinds. But that's not really what this post is all about! The dealer installed the Blue Ox SwayPro BXM1000 and said everything was set perfectly but after a closer inspection I noticed a few issues in the setup from what I've read online. I decided when I got home to redo the hitch setup. I think I have it setup properly but I'd like to run the measurements by everyone and get your opinions!
Here's a little info on the truck and trailer....
2016 Ford F150 FX4
Goodyear Wrangler Fortitude 275/65r/18 ( Garbage Tires I Know!) 35 psi
2018 Apex 245bhs dry weight around 4600lbs
Tongue weight is around 14% at the moment with propane and battery. Trailer is not loaded yet.
Now for the Measurements!
With the trailer level the top of the ball coupler is at 24 1/2".
Top of the ball in the receiver is at 25 1/2"
1" difference in height.
Truck tire "no trailer" measurements from ground to fender.
Front 37 1/8"
Rear 39 5/8"
Truck Measurements with the "trailer attached" and SwayPro hooked up.
Link #9, 3 1/2 links showing below rotating latch
Front 37 1/4"
Rear 37 3/4"
Link #10, 2 1/2 links showing below rotating latch
Front 37 1/8"
Rear 37 7/8"
To me Link 10 might be the better choice. The front axle is the exact same height loaded with the WDH installed as the "no trailer" height. The truck has a 1 3/4" sag in the rear but only a 3/4" difference from front to rear.
The trailer on link 10 is perfectly level to the ground when measuring font and rear points on the frame.
Now another question is about my tires!
I've done a little reading and I'm finding out that my tires are not the best for towing.
At 35 Psi I read the sidewalls are extremely soft and can cause the truck to feel like its swaying back and forth. I looked at the sidewall and it says Max Pressure 51 Psi.
Should I be running the tires at Max Pressure when I'm towing?
I'm a little scatterbrained right now so I hope this makes sense!!!
