Mike_Up
May 05, 2018Explorer
PolarisRich wrote:
Now correct me if I'm wrong but I believe I'm at 920 pounds roughly of tongue weight. And if the trailer weighs in at 5580 lb that means I'm at 13.9% tongue weight?
Subtract your Blue Ox weight from that 920 Obviously, which is around 100 lbs. So your tongue weight is really only 820 lbs. You said you left the hitch in for the truck weighing but didn't mention if you left it in also for the truck and trailer weight without the WDH hooked up.
None the less, you have a pretty heavy tongue weight.
44,071 PostsLatest Activity: Aug 30, 2026
