SoundGuy
May 20, 2018Explorer
ktmrfs wrote:
recomended torque on a 3/4" grade 8 course thread is 282 lbs. for an unlubricated bolt. Lube it and the spec goes DOWN. In any case your over double the recomended torque for a 3/4" bolt. likely at or beyond the yield spec.
Equal-i-zer installation requirements, from Progress Mfg ...
Using an adequately rated torque wrench is the only correct method of properly tightening those shank bolts, leaning on an extension bar with your body weight is not. ;)
44,052 PostsLatest Activity: Oct 12, 2025
