SoundGuy
May 20, 2018Explorer
jerem0621 wrote:
Time for a new tool! 600 lb ft Tq Wrench!
Therein lies the rub and is why I'll probably not own another Equal-i-zer again. Unfortunate, because the EQ performs well once properly adjusted but it took me at least a half dozen tries to get mine properly set up, the problem being that because head angle is set by head washers those darned shank bolts had to be loosened, removed, and retorqued each time, and for that I required a torque wrench capable of 320 ft-lbs, a tool I didn't own but had to borrow from a friend each time. I later changed tow vehicles and had to go through the entire process all over again ... sure was a PITA, 'though once properly set up it did always perform well, albeit with a fair amount of noise. Now that other systems are available that also perform well but which don't use washers to set the head angle or those like the Blue Ox Sway Pro that have a fixed head and don't require the use of a torque wrench I don't own it I doubt I'd ever buy another Equal-i-zer.
44,066 PostsLatest Activity: Jul 25, 2018
