Huntindog
May 26, 2018Explorer
lbrjet wrote:Same here. I am on my 3rd one. I had a 10K, 12K, and now a 14K.mike-s wrote:SoundGuy wrote:Well then, you just need to buy the proper tools.
Disagree completely, the only way to know for a fact that your Equal-i-zer is properly set up for both the TV and trailer is to take the combination for a tow, over a variety of road surfaces, both wet and dry, and at varying speeds to see how it behaves ... and it will behave differently, the recourse being to take it apart yet again and reset those head washers until you get the system functioning as you believe it should, and that does mean re-torquing those head bolts each time. BTDT many times, it does make a difference.
Soundguy,
I set mine up according to the instructions 7 years and 25,000 miles ago and have never touched the shank bolts since. Have no clue why you would have to do it over and over. 250lb torque wrench and cheater bar for the shank bolts and a 40 inch breaker bar for the ball.
Each one was perfect after the intial setup, (following the instructions.)
44,066 PostsLatest Activity: Jul 25, 2018
