- HarleybulletExplorerBill link is above in posts...I can do it manually.... if there is no weight on the jack I use a portable drill with a 1/2 " hex socket and when there is weight on it I use a large breaker bar... the handle they give you is a lot of work....no leverage.
Dave - Fisher_BillExplorer"now power to both sides and 3 of the 4 go up and down (left rear frozen)
They also sent by email schematics for the jacks and some tips on getting the 4th working."
Is it frozen or can you still use it manually? Mine still works with the crank but would like to get the tips from Happijack if you can post a link or something.
Bill - HarleybulletExplorerHi Dave here the OP. I contacted Happijack and they were very helpful and knew what they were talking about.
The fuses (2) were 30 amp located under the sink (not the best place); I switched them around and the original side that was not getting power worked... so I replaced the right side with a new fuse....now power to both sides and 3 of the 4 go up and down (left rear frozen)
Will post when I get to that 4th one.....thanks for all your tips and help.............Dave
Soon I will be on my way...out of the cold...which really has not hit Long Island NY yet! - Fisher_BillExplorerMy 2000 1150 has the wires under the step to bed. When I bought it we were loading and battery was low and we blew the fuse. Changed it out and hooked up to shore and then worked well for couple of years but now the rear left stopped a month ago so I need to track that down.
Happijacks. Anyone else have this symptom? (Please pardon hijack) - jmckelvyExplorer
kerry4951 wrote:
Gripnriprod wrote:
Here is a link to Rieco Titan troubleshooting flyer.
If its an older AF then it might still have the original Happi Jacs
True. The OP indicated it is a 1995 model. A friend has a 2005 AF which has the Happjacs. My 2013 has the Riecos. Don't know what year they switched jack brands. - kerry4951Explorer
If its an older AF then it might still have the original Happi Jacs - mkirschNomad IIIf it's a blown fuse, there's a reason it blew. Replacing it without figuring out why it blew is generally not the solution.
- GripnriprodExplorerHere is a link to Rieco Titan troubleshooting flyer.
- RamTCExplorer
Harleybullet wrote:
Is there some sought of fuse or other item I should look at.... could it be the remote wired controller? Arctic Fox 1150, one slide, 1995
Yes, the fuse is under the sink, each side jack pair shares a fuse, 30 amp as I recall. - Old_DaysExplorer IIFirst I would take each plug out and see if they are dirty and need cleaning,then put some dielectric grease on each plug. Some times that is all it takes. The fuses are by the control board.
