Cummins12V98
Aug 23, 2018Explorer III
Larry-D wrote:
Using a RAM dually for almost three years as a DD. I've found and don't miss going through drive-ups (they always get the order wrong anyway). Don't miss bank drive-up, better to go in and get to know them. Parking - just park further out. Can't do automatic car washes. On the plus side not as many people pull out in front of you. Tires - front wear out twice as fast the rears.
Run the fronts at 80psi, have the alignment done to 1/32-1/64 toe in. Fronts will last MUCH longer. Also move fronts side to side leaving wheels in same position, this keeps tires rotation the same and puts inside to outside. I never rotate rears. Also run 30-35 unloaded rears.
