Surviver76's avatar
Surviver76
Bought New/Used TT & Pro Mover Says Can't Pull It Out!!!
Hi Guys, my girlfriend purchased a very nice 31 foot TT and unfortunately neither of us noticed that the overhead heavy wooden structure had been built up quite close to the rig after it was initially parked. We sent a pro RV Mover over to pull it from the park to our house just 14 miles away and he wants 7 to 800 bucks to "jack it up & use rollers to move it sideways" in order to merely pull it out of the spot.
I once rented a small but powerful "personal forklift" type of vehicle from Home Depot to pull in a 5th. wheel trailer where my truck would not have been able to get out of. I just needed to shunt the rig forward a little at a time and it worked. Wondering about doing something like this in this instance.
I do have Good Sam's Roadside service and also thinking about calling them to see if they can just get it out of the spot... Jammed Up!
  • I don't think a professional mover, Good Sam or any paid service is going to touch that for liability reasons. Far too risky to damage trailer and structure.
    I believe it's on you to get this out and moved. If it's on concrete consider removing tires and using blocks under the axle tall enough to make sure the drums don't touch the ground and put plastic nylon cutting boards under it. Will be far lower than a dolly and slide pretty easily. Recommend hand winching it out too to prevent damage.
  • Wow thanks guys for all the quick responses. I'll get to work on it right now... All great points! Thanks again... M
  • If it is on a concrete pad, and you only need to lower it about 6" you may be able to rent some vehicle dollies. Raise it, remove the tires and then set it on the dollies at all four corners.
  • Hmmm. Not sure owner has "delivered" the TT to you when it can't be moved from his/her property. Interesting you didn't notice that issue. Check those tires. Let the pro do it.
  • Lower the tire pressure on other side to move top part of trailer away from awning. Is there room on other side to do this? Remove awning to get more clearance on one side. Hire a better RV driver?
