Gdetrailer
Oct 30, 2021Explorer III
Incadescent bulbs draw a lot of wattage which with enough load can cause switches to get "warm" but not hot to touch.
Someone could have replaced the original bulb with a bulb that draws a higher wattage for more brightness which could be bad.
May wish to consider finding LED replacement bulbs to fit your fixtures.
Hard closing doors are sometimes caused by misalignment of the door, warped, rotted door or worn hinges causing the latch to not engage correctly in the frame.
Verify the latch is centering with mating latch surface in the the door frame correctly and that the door is not warped, tweeked or rotted out.
