MFL
Oct 30, 2021Nomad II
You show a pic of actual switch, and then the light fixture? The switch should not get VERY warm, but the fixture/bulb will.
I have used a slight amount of clear teflon trailer ball lubricant on my door strike and latch pictured. Works very easy for a long time. I don't just wing/slam the door shut, most times, just push it shut, often times using the pull handle when doing so. RV doors aren't built like a truck door.
Jerry
Jerry
