Gdetrailer
Oct 30, 2021Explorer III
Latch assy may need a little light lubrication on the edges (top/bottom, sides), adding lubrication to the gliding surface of the latch is pretty much futile as it will just wear off or end up on your hands and clothes over time and the issue just comes back until you relubricate.
I have never lubricated the gliding surface of my latches on my current TT and they work perfectly. Wasn't the case with the original doors on my current TT as they were totally destroyed by water damage and sagging.. I built new doors from scratch, no more latching issues..
Not saying your doors are toast, just saying that a little sag or misadjustment in the door can be a real drag on the latch.
Have you tried the doors with stabilizers down to see if that makes a difference?
Sometimes overtightening the stabilizers can temporarily tweek the trailer frame enough to cause the doors to stick or be difficult to open or close.
