MT_BOB
Oct 30, 2021Explorer II
#1 That looks like an RV Designer switch. Their switches are rated for 10 amps. You could run 1 to 2 headlights off of it. However, lots of their switches use flat spade push on connectors,commonly called quick disconnect connectors.They can corrode, they can become loose where they slide on the switch.Can also corrode at the wire crimp.Pull out the switch,look for these.Also,look at back of switch,for signs of melting.
#2 Agree with some other posts, spray out latch assembly,wd40 will clean pretty well, but not leave a lubricant.So then spray with something.White-lube is good,and does not stain clothes.PB Blaster will clean and lube,but stinks.After all that,still does not hurt to lube the contact face with wax or soap.
Has been my experience on older campers, things get out of wack enough you have to pull the release while pulling in on the door. Door replacement can be expensive.
