fla-gypsy
Nov 20, 2012Explorer
MegaJohn wrote:kaydeejay wrote:
Do any of your wires pass through the axle? Very common issue of insulation chafing at that point causing an intermittent fault.
You can replace the wiring, or sleeve it in plastic conduit to keep it away from sharp metal edges.
Dollars to donuts that is where the issue is, unlikely to be the truck.
Thanks for your help. The wires DO pass though the axles... I'll check that first! ;)
Happy Camping!
John.
x2, Most likely place for failure
