westend
Dec 10, 2012Explorer
Before you pull the hubs, I would check the wires to the connector on the truck. It's easy enough to inspect. I was pulling at my hair and finally found that the brake wire to the 7 pin connector on the truck is at the bottom. The wire to my connector must have been hit by a road hazard and the semi-parted wire was corroded and only giving intermittent power to the connector. I had to strip the sheath off the wire to find this but could feel the break, first, by moving that wire.
Good luck with the brakes.
Whoops, saw you have it fixed, travel on!
