- Cummins12V98Explorer III
ford truck guy wrote:
My mechanics BOTH told me that the rotors of today are pretty much 1 and done…. He has not turned 1 in a few years on newer vehicles…
They DO NOT make them like they used to ! ! ! !
That’s a load of Barbra Streisand. It all depends and all it takes is to use a caliper. Most Mechanics just want to replace parts and the fact is the OE parts are superior to what they change out to from NAPA and the like. Is you want something other than junk you need to say so and be prepared to pay up.
I have owned ONE vehicle that the rotors could not be turned and I have driven WAYYYYY over a million miles so many brake jobs under my belt with the rotors always being turned. - My mechanics BOTH told me that the rotors of today are pretty much 1 and done…. He has not turned 1 in a few years on newer vehicles…
They DO NOT make them like they used to ! ! ! ! - Garry_GayleExplorermy last 2 trucks when the pads wore out the rotors were close to minimum
thickness and I prefer thicker the better for heat dissipation. - Cummins12V98Explorer III
Garry&Gayle wrote:
I think I'm going with the Akebono Euro Ultra Premium pads and NAPA premium coated rotors upon recommendation of a pro mechanic that also tows heavy.
Why wouldn’t you just turn your rotors? - Garry_GayleExplorerI think I'm going with the Akebono Euro Ultra Premium pads and NAPA premium coated rotors upon recommendation of a pro mechanic that also tows heavy.
- BenKExplorer
Garry&Gayle wrote:
I have thought about EBC but they are the most expensive too. I will look into the others suggested also.
Have tried most brands and from OEM to performance to race...always have ended up with either Hawk or EBC after buddy had his friction material research company bought out (his recommendation & he works for one of them now)...no longer get experimental stuff and have to buy them now.
A lot depends on how you drive and where you place go vs stopping. I like both, but stop is on top.
Me...can smoke OEM, standard duty, and some HD pads in a hurry and need/want performance level or higher. Understand the downside of them being almost nothing when cold
Currently, have Hawk on my Suburban, 1996 K3500, 7.4L and will get these for the next set. Wanted them, but they weren't available when I needed them...may just purchase a set to have on hand =
EBC Brakes DP41268R - EBC Yellowstuff 4000 Series Brake Pads for 1996 K2500 Suburbansummitracing wrote:
$176.80
Brake Pads, Yellowstuff, Aramid Fiber, Front, Chevy, GMC, Dodge, Set
EBC Yellowstuff 4000 Series pads are the perfect replacements for your daily-driven race car or ultra-friction truck upgrade. They're made from a full race material and are capable of high-temperature use, with a very good wear life. Their "bite" from cold is superb—uncommon with race materials, which normally require warming-up—making these pads safe for use on the highway, as well as on the race track. EBC pads deliver increased stopping power for your performance race machine and your demanding truck or SUV. These are not "low-dust" disc brake pads, but are similar to or better than OE pads. Order the set designed for fitment on your make and model.
Edit...notice that most all higher performance pads these days has one or two slots molded into the friction material.
That negates the 'need' for drilled and/or slotted rotors.
Outgas escape routing to not float the pads off of the rotor surface when very hot and outgassing.
Without the holes or slots on the rotor, there is more surface area for braking & thermal mass to both hold & carry away heat from the mating surface with pads. - Grit_dogNavigator III12Vs comments about the OrangeStuff pads are correct, but the rest of it is a bit to broad or general.
Heck, newer GM light and heavy duty pickups come with ceramic pads. Or if they're not, I've never seen an organic or semi metallic with that little brake dust on the wheels.
Pads that have worked well for me on HD pickups.
EBC Super Greenstuff (truck and SUV, not the normal greenstuff pads)
Powerstop Z36 - Cummins12V98Explorer III
I have the EBC Orange HD pads on my 01 RAM Sport all around and on the front of my 15 DRW.
The difference was insane on the 01 and dramatic on the 15 with only doing the fronts. Only did the fronts because the rears were not available at the time. Didn't need pads but wanted improved braking and it made more difference than another pad I have ever used. I also use the EBC Yellow on my HEAVY Mobile suites and they work great.
Ceramics are NOT designed or intended for HD use!!! If you look many of the so called ceramic pads for HD they say "Ceramic like". - theoldwizard1Explorer III like Raybestos, but make sure to get their Premium Ceramic pads.
- APTExplorerI am a big fan of Powerstop pads and rotors. I have them on my Suburban for 30k miles as well as my DD Subaru Outback (F 10k, R 25k miles).
44,056 PostsLatest Activity: Mar 02, 2026
