RoyB wrote:
My 2010 Ford has a pedal adjustment lever on the dash...  Sort of figured the other truck guys been doing the same thing...
Roy Ken
Actually, Ford does not automatically include the adjustable pedal in ALL trucks or trim packages. Depending on the vehicle and trim level you must select an additional option package to get the adjustable pedals.
Example, my 2013 F250 the XLT trim did not include adjustable pedals, but fleet orders of XL package got them..
XLT package I had to order another option package which included the horrid "Sync", stupid backup sensors and a couple of other useless items..
Lariat and Platinum packages was included..
Honestly, after having trucks since 1997 I can say that adjustable pedals SHOULD be a standard feature.. It is a safety issue and without them my DW would HAVE to move the seat all the way up and she would be TOO close to the steering wheel airbag!
I was under the impression the Ram had adjustable pedals, they did back around 2003.. Found that out back then when I bought a Jordan Ultima 2020 brake controller. Had to specify Ford or Ram when buying.. Had two different brackets for the brake control wire connection..
For the OP, what could be done is perhaps add some firm padding UNDER the carpet.. Just have to make sure the gas pedal will easily clear the carpet (which is most likely why the pedals are so high in the air)..
