stevemorris's avatar
stevemorris
Brake Upgrade
our new to us 15 yr old 3000 lb tt has very feeble braking action. it has dexter 2200 lb axles with 7 inch brakes
despite a total check and setting up(brake lube, adjustments)and a very thorough check over of the electrical system, braking is very poor. with the trailer on jackstands, the breakaway will lock all 4 wheels, on the road, virtually nothing
our previous tt with dexters and 10 inch brakes would lock up all 4 wheels easily on the road(manually) and the brake controller would give nice braking action at 30-35% power. this tt does almost nothing at 100% output
so I'm thinking the brakes are too small. up grading to 10 or even 12 inch brakes looks fairly simple, spindles, bearings, wheels look identical
comments?
sources for the total package?
  • well dexter 3500 ales are way off the budget, so I'm stuck with optimizing the 7 inch brakes. or finding a bearing that will fit between the spindle and the 10 inch drum/hub
    funny thing is that the manufacturers' brochure says that the tt came with 10 inch brakes
  • I've had snowmobile and camping trailers with the 7" brakes for 39 years. They are nothing but trouble. One issue that has been the most frequent is the clip that holds the magnet comes off. While you would think that there is not enough room for the magnet to come off the post, they will. My solution was to silver solder the clip in place. To do this, place a large washer over the magnet to protect it, and push the magnet back exposing the clip.
    I had adjusters where the teeth would just crumble and those parts are no longer sold separately. I made my own adjusters from stainless steel. Lube the threads with anti-seize.
    I have tried brands other than Dexter, but had magnet wires break off first trip. There is no good answer that I have found. Over 30 years ago, the brake shoes had riveted linings and generally were made better. They worked well, but there was only 1/32 of lining above the rivets and needed replaced every time you looked at them.
  • well a new update, one of the magnets wasn't doing anything, vom shows infinite resistence, so its burnt out
    got a new magnet, wired it up with new cable from the junction box. now both brakes on the drivers side have a good solid connection and I get a solid "clunk" when I power the breakaway system with two brakes energized
    so now I have both driver's side brakes fed by a new 12 ga cable, now I'm going to run a new cable from the junction box to the curb side brakes
    I'm stripping and soldering all splices, i'll cover them with heat shrink stuff when its done, ive also added a return wire from every wheel, this will eliminate any grounding issues
  • ive had the entire system apart, right down to the shoes off the backing plates.
    10 inch brake/drums use a different spindle than the 7 inch so bearings are not compatible
  • I heard back from dexter, apparently that axle wasn't available with 10 inch brakes.
    but husky has brakes that would appear to fit ok
  • Best bet is to call Dexter directly and ask if the 10" brakes can be fitted to your axle. If not, you're looking at a new 3500# axle.
