wowens79's avatar
wowens79
Explorer III
Sep 02, 2016
Brakes grabby at low speeds
We've got a new TT, with a Prodigy P3!brake controller. Brakes work great and smooth at road speeds, but at campground/parking lot speeds they are grabby. I've tried different boost settings, and voltage settings. I can't seem to find the right combination. I had the same problem with our popup, same controller, but different TV. It wasn't as bad I think because the pop up was so much lighter.
Is this normal, and something I just need to get used to?
Also when coming to a stop, and you ease up on the brake is does the same thing.
Any suggestions of settings to try? I run the voltage around 10, and the boost on B1, or off
Thanks
