kaydeejay
Jun 23, 2015Explorer
Pull harder! These are not meant to slide out easily. If it really won't move then a shot of penetrating oil left to soak overnight may be in order.
Why are you trying to remove it?
If you just want to test the system that's OK, just don't leave the pin out too long.
If, as some others have tried, you want to use the brakes to hold the trailer in position, that is not a good idea! Your brake magnets will get hot and the battery will drain rather quickly.
