cbshoestring
Jun 23, 2015Explorer II
GaryWT wrote:
Why do you want to take it out. Just leave it there and be sure it is connected to your TV when traveling.
Testing the fact that it does come out is part of annual DYI inspection. You want to make sure it works.
Jporter1313 wrote:
Yes the box is attached to the the trailer and then I attached the other end to the car and I need to get the pin out if the box to get the car away from the trailer and then I put the pin right back in
Me confused :h I thought you were just doing a test. If you are moving your vehicle, why not just disconnect it from the TV. It is on some sort of removable attachment, right????
