Old-Biscuit
Jun 23, 2015Explorer III
Jporter1313 wrote:
Yes the box is attached to the the trailer and then I attached the other end to the car and I need to get the pin out if the box to get the car away from the trailer and then I put the pin right back in
Pulling pin to move car........not the normal way to do things.
Cable should detach from car and pin remain in switch.
Pin should only be pulled as a test...with pin out FULL Battery Voltage is being applied to brake magnets
Pin typically only goes in one way so if last time it was inserted wrong it is jammed.
Can't pull pin.....then you need a new switch.
