Muddydogs
Jun 23, 2015Explorer
Use your knee as leverage. If that doesn't work something is probably jammed up so at that point cut the cable or drive the rig forward and make it come out then replace parts as necessary.
What some of these guys are alluding to in there usual way is its best to not pull the pin and run it through the loop to secure it to the rig each time you hook up or unhook as you just found out it can wear the plug and pin which can cause problems. I picked up a cheap carabiner that clips over the loop and then gets clipped to the rig so I don't have to pull the pin all the time.
