donn0128
May 29, 2013Explorer II
Are you using a factory made harness from controller to the correct input on the fuse panel? I suspect if you made the harness up and simply swapped from one vehicle to the other that that is your problem. GM has made several changes over the years, and unless you have the correct harness it wont work.
44,025 PostsLatest Activity: Feb 26, 2025
