panteramatt wrote:
Sjm9911 wrote:
What kind of camper do you have and what does it normally run at? Is it a 50 amp plugged into a 30 amp? My TT will run ac, fridge ( just one), ellectric water heater, and microwave etc just fine. Are the fridges built in or did you add them? You can always run a hevey duty extention cord for extras to your power pedistal. What type of cord did you use?
Its a 32ft COugar TT 30 amp. It has a built in refridge indoor and outdoor. The extension cord I used was very heavy duty.
The longer you go the heaver you need, here is a standard 30Amp RV extension.
https://www.lowes.com/pd/CAMCO-PowerGrip-25-ft-10-3-3-Prong-Indoor-Outdoor-STW-Super-Heavy-Duty-General-Extension-Cord/3455554
