myredracer
May 25, 2018Explorer II
If you're unlucky in it not being the fuse, there's always the chance it's a bad connection somewhere. A bad connection may or may not be hard to find. If not a fuse, perhaps start by pulling the wall plate off and use a voltmeter to see if there's 12 volts at the wall plate. Suppose it could be a bad wall outlet/plate too. I've had loose wires at crimp connections including one where the wire fell right out when touched.
44,055 PostsLatest Activity: Dec 23, 2025
