The entire dipstick tube is gone? You didn't what engine is in your truck. I looked around. If you have a gas engine it appears to only be difficult. Diesel is something else. I found something that might help? Again, didn't know which engine applies to you.
SECTION 303-01B: Engine — 6.8L 2000 F-Super Duty 250-550/Excursion/F-53 Motorhome Chassis Workshop Manual
IN-VEHICLE REPAIR Procedure revision date: 06/21/1999
Oil Level Indicator and Tube
Removal
Remove the engine air cleaner (ACL) (9600) and the air cleaner outlet tube (9B659); refer to Section 303-12.
Remove the left exhaust manifold (9430); refer to Exhaust Manifold—LH in this section.
Remove the bolt and remove the oil level indicator tube (6754).
Inspect the oil level indicator tube for damage.
Installation
To install, reverse the removal procedure.
Replace and lubricate the O-ring seals with Super Premium SAE 5W-30 Motor Oil XO-5W30-QSP or equivalent meeting Ford specification WSS-M2C153-G.
Install the left exhaust manifold; refer to Exhaust Manifold—LH in this section.
