Bedlam wrote:
It is not a motorcycle rack or motorcycle off the rear. The owner had two e-bikes which weigh 60-80 lbs each. Verify your information before posting or I will delete posts or lock this thread. This failure was on a 2020 Ram 3500 DRW crew cab long bed.
OK, so 2 x 80lb bikes plus 60-80lb for the rack...or around 250lb several feet back from the rear axle bouncing down the road acting as a big lever while the 6500lb (loaded) camper rocks back and forth. If they get into sync, it could easily tear the frame apart. Plus fatigue damage from the 25k miles, it might have done OK initially but eventually, that will weaken the metal.
The simple fact it bent upwards in the middle suggests it was too much weight at the back as the front of the truck doesn't appear to have any modifications adding weight to the front. If it had bent down, that would have suggested too much weight between the axles.
I'm still waiting on pictures of the frame itself. If the frame was modified and then grossly overloaded on a rough road...nothing surprising that it eventually gave out.
