Suburban does NOT use the 'thermal fuse' like Atwood
You dry fired it........hopefully you did NOT put cold water in it until AFTER tank cooled down!
Check the high temp t-stat 'reset'
In outside compartment is PUSH TO RESET button above gas valve.
Good chance it tripped.
Only other thing would be a blown main fuse in DC DIST Panel for the water heater
WAIT A MINUTE:
This 'dry fire' issue is SAME thing back in Sept of 2015
Did you dry fire AGAIN....or did you just ignore the responses from 9/7/15
Last years post ----SAME issue!:S
