swimmer_spe's avatar
swimmer_spe
Broken window temporary repair
I may be purchasing a used TT. One of the windows were broken in a windstorm that happened a few days ago. The current owner has taped up the damaged window so that it does not leak.
If I get the trailer, I want to fix it slightly more permanent for the winter. What could I do? It is a rounded window.
In the spring, I will get a new window for it.
  • Old-Biscuit wrote:
    Replace it now...then you don't have to worry about winter and intrusion thru a taped up, tarped up, plastic sheet cover, duct tape hap-hazard mickey mouse repair
    Water is an RV Killer.....avoid at ALL COSTS
    I agree...and I love the graphic description!:B
  • Look at it and see if you can remove the broken window frame. Then find a local glass shop and see if they will make a template and replace the glass for you. I've had to do it twice on my emergency exit window. It wasn't cheap, but I got it repaired.
  • Replace it now...then you don't have to worry about winter and intrusion thru a taped up, tarped up, plastic sheet cover, duct tape hap-hazard mickey mouse repair
