BurbMan's avatar
BurbMan
Explorer II
Jun 03, 2020
Brophy Tie Downs?
Guys, anyone use the Brophy Universal Tie Downs?
Says they are universal and fit in the stake pockets of the bed. Also a fraction of the price of the Tork Lifts.
Are these any good or is TL the only way to go?
  • I see you have Ram listed in your profile?
    I used Ram's bed from 2000's and that thing was cracking like crazy.
    Had to reweld it several times just to hold it together.
    Would I want my camper attached to it > NO WAY
  • Haven't used them. Considered them when we got the first camper because they were cheaper.
    I'm sure they work, but I've found its pretty easy to bend the top lip and top of bed rail on newer trucks. Just the J bolts that attach tool boxes bend the top bed rail. I anticipated damage to the bed with these and went with frame mounts. Also appeared to not allow a long enough connection to get any sort of spring loaded connection in the turnbuckle/chain assembly.
    Older truck and/or small camper, maybe, IMO. New truck with fragile thin sheetmetal and a big camper, not so much.
    JMO.
    Similar with Happijacs. I'd consider the front Happijac mounts to be secure and would use them based on how they distribute the load, but I'd never use the bumper buttons if I wanted to keep my bumper straight. The old 86 Chevy we just bought has one side of the bumper tweaked from HJ mounts and it's a real bumper. Newer bumpers are tin cans comparatively.
    TL, while expensive also offer the best angle/location for mounting. The bed and bumper mounts require much larger angles between the camper and the tiedown, which structurally puts more/different stresses on the camper brackets AND is continually "pulling" on the truck bed vs the frame.
    I think in this case, you truly get what you pay for.
