WNYBob wrote:
Sorry but you just lost thousands in resale value!
Delamin8is most of caused by moisture in the Luan behind the fiberglas! Maybe a minor leak around the window.
I will not buy an RV with WOOD backed fiberglas!
Kind of severely limits your choices then, in as much as 90% of them today are vacuum bonded fiberglass (Filon) over wood substrate.
I'ts delamination for sure probably cause by water intrusion from a leaking window seal. Seals and caulk need to be checked and maintained a couple times a year, something very few owners do until bad things start happening. The they 'reactive' instead of being pro active.
