RickW
May 02, 2019Explorer III
Another approach would be to install a copper tube coil on the outside of the water heater tank (or a flat coil on the bottom of the tank if sufficient clearance), insulate and use a recirculating pump to distribute the heat.
I would probably just recirculate the hot water directly from the tank to a radiator and turn off the pump system when taking a shower.
In any of these approaches, the output might be enough to maintain comfort but would not initially heat a cold TC anytime soon. You might need a portable heater (electric or propane) for initial heat up.
