Bobbo's avatar
Bobbo
Explorer III
Apr 21, 2017
Building a Dodge, oops, Ford TV
I have an appointment Monday at Dodge to order a truck to be built for me.
Question: Should I spring for the Anti-Spin Differential Rear Axle for $435 and/or the 4-Corner Air Suspension for $1,715?
I am new to towing. It will have the 3.92 axle (as opposed to the 3.21 axle). The 3.55 axle requires the EcoDiesel or the V6 gas engine.
  • Truck shopping is fun!
    Going half ton, yes limited slip and as deep of tears as you can order. No air ride.
    IMO the disadvantage of the Rams is the low payload and limited options to shore up the coil springs, but I'd still go Ram if that's what you're after. You can get air bags and maybe? Timbrens type springs if you need to help the coils out.
    Go for the hemi or eco Diesel. eco D is a bit down on power but a small tune wakes them up.
  • What are you planning to tow? And is a 1500 really enough truck once its loaded with family.
  • They shouldn't even offer trucks with open differentials. IMHO of course.
    Yes, get the limited slip. The air suspension is nice, but I'm also leery of it. There have been reports of it malfunctioning in below freezing weather, which happens around here often enough.
  • If you are going diesel, ram is your answer. Every truck made should be ordered with a limited slip rear diff. So yes order that. Air bags might be necessary or helpful but you didn't tell us what you tow, so we can't answer.
    If buying a gas truck (poor choice in my opinion) then Ford is the only way to go. Ecoboost is the only way to go.
  • Skip the 1500 150 option and go with a 25 series if you will be towing over 6-7K lbs or anykind of 5w. You will not have the payload. Power yes, payload NO! Get heaviest gvwr option you can, ie 7200-8400 in a 15 series.
    LS yes, air no.
    Marty
  • Yes to anti spin, no to rear air. More problems than they're worth. Is the truck going to be a tow vehicle or toad? The Rams have very little payload for towing.
  • Is this going to be a 1500, 2500, or 3500? Me, I would opt for Anti-Spin Differential Rear Axle for $435 it will have more use towing or not towing.
  • Bobbo's avatar
    Bobbo
    Explorer III
    Actually, I have Ford getting me a price too. I just didn't have any questions about the Ford build.
    The Ford MSRP is $43,330, the RAM MSRP is $34,655. That is 25 percent more. They will have to make me a REAL GOOD DEAL because DW won't go for a 25 percent premium just for a Ford.
  • my vote. keep driving, hit the ford dealer
    I just played this game in jan and ended up in an f150
    if you are stuck loyal to dodge I say yes limited slip diff, no on air.
