In our continuing search, we were told yesterday that tongue/hitch weight only matters if you're planning to use a bumper ball for towing. If using a towing hitch attached to the body, you can tow th...
If you went in with a 1/2ton or bigger truck shopping for popup campers, it's probably partially true in the sense that with a reciever hitch you are unlikely to be anywhere close to the limits regardless of the which popup you are looking at.
Once you get into full hard sided TT's, it's absolutely false.
