I want to be able to mount my Champion generator on the rear bumper, which means replacing it. So would 3/16" square tube with 3/16" plates, angles, etc. welded to the frame be strong enough? I am th...
You better be really versed in weights and balances before you begin this venture. You're not only adding the weight of your gen-set, your also adding a lot of weight from the steel.
