That's why we went to a hard side. Had a Forest River Rockwood pop up and while the tent didn't leak, it just fell apart. Then the tent got damaged by the service department doing warranty work on other things! It spent more time in the shop than my drive way or the campground. Traded up to a StarCraft. It was very very reliable and was built excellent. The problem was the Aqualon tent. It leaked. It was 1 years old and I was fighting leaks on the bunkend in the upper corner seams. StarCraft replaced the bunkend. 1 year later the other bunkend started leaking. StarCraft was closing. They agreed to replace the bunkend but replaced it with the wrong one as there was a mid model design change in 2007. It fit but was loose and didn't match the other bunkend. We had enough of tent leakage and the such, on an expensive NEW camper. So I traded to a 23' travel trailer in 2008.
I will tell you I used Seam Grip and the water based seam sealers. NONE WORKED!
Previously talked to StarCraft customer support, they said use Paraffin wax to seal the seams with. Then later said they'd just replace the bunkend. At the pop up forum here, others agreed wax is the way to go.
I really wish I never had them change the bunkend and just used wax to seal the seams. I really liked that pop up but after we got soaked in a thunderstorm from water literally pouring in through the needle holes, my wife would NOT camp in it again even after it being fixed. She hated it that much, plus the work it took to pack everything in it and out of it. Setup wasn't bad just the packing since it had no storage.
I don't regret getting rid of it as the tent problems were such a disappointment. Plus I really don't know if the wax would had even sealed the water out.
Even the Rockwood kept getting holes in the vinyl top where I had to keep sealing the actual vinyl. Then the dealer causing tent damage while doing warranty work on something else.:M I love tents just not on my campers anymore. :)
If all fails, I'd try wax but make sure it's recommended by your tent and camper maker.
