- AH64IDExplorer
jlelm2014 wrote:
2013 Gulfstream Conquest 255BH
I just looked at the floorplan, those are double bunks.. They will have a rating over 150-200lbs (or as an owner I would be furious). - DutchmenSportExplorerMy Keystone (upper bunk - full size bed) had a rating of 350 pounds. We had more than that on it. I think that's the recommended "max". Chances are it will hold more, but if you put more on it and it collapses the manufacturer is not responsible. Then if you attempt to sue the manufacture they have their disclaimer and you were warned, so you don't have a leg to stand on by way of law suites.
- colliehaulerExplorer IIIMy last Gulf Stream TT with bunks was rated at 150 lbs. Had a max weight sticker. You can call Gulf Stream and ask if unsure.
- wmosesExplorer
modern family wrote:
That is what I have seen in the past.
No idea, but the average is around 200 pounds - jlelm2014ExplorerOk, I will check under the mattress. Thanks for the tip ah64id.
- AH64IDExplorerBoth models of TT's we have owned have had bunks rates at 350lbs.
There should be a weight sticker under the mattress if it's not visible. - jlelm2014ExplorerThanks for the input Modern Family. Have a nice camping season.:)
- modern_familyExplorerNo idea, but the average is around 200 pounds
44,067 PostsLatest Activity: 2 hours ago
