librty02
Aug 06, 2019Explorer
And also if you decide on going to look at a 3/4 ton truck you must also watch their payloads. A 3/4 ton gas truck will have a lot more payload than a 3/4 ton diesel truck does. Heck I've looked at some loaded up 3/4 ton diesel trucks before that had payload capacities as low as the 1600 lb range...most don't go over 2100 lbs unless they are less optioned models. So if you would decide on a diesel I would highly recommend a 1 ton as it will have more payload capacity at very little cost difference than the 3/4 ton. But honestly a 3/4 ton gas would fit your bill perfectly and most likely not cost much more than that 1/2 ton Suburban...good luck in your search
