JRJ10's avatar
JRJ10
Busted water lines
I have a 2015 Prowler. I was out of town during an unexpected freeze. Fitting under the sink and the pump busted. I bypassed the pump and replaced the fittings but when I turned the hose on I have just a trickle from my faucets and water is pouring out of the fresh water fill hole. I'm new to the RV world and have no idea what the problem is.
  • wnjj's avatar
    wnjj
    Explorer II
    enblethen wrote:
    Water tank is full. When you bypassed pump did you put in check valve to tank?
    What he said. ^
    You need to cap off the line that used to exit the pump, not bypass it. You’re filling your tank via the pump inlet hose.
  • Water tank is full. When you bypassed pump did you put in check valve to tank?
